I'm bringing in an avi file (movie) but it is type 1. If I take this file and encode with TEMPEnc to a mp2 using system video and audio the movie and sound are ok. If I try to convert the avi type 1 to type 2 using the DV Type 1 to DV type 2 converter (found in the tools section) then open the file in either Goldwave or Sound Forge, every 20 minutes the audio is maxed out (I mean nothing but this loud noise and the left and right channels shown in either software is nothing but a solid color no visual peaks of any kind). What could I be doing wrong with the avi conversion that is corrupting the audio like this.
Results 1 to 1 of 1
audio problem when converting
By Stevex70 in forum Video ConversionReplies: 0Last Post: 25th Mar 2011, 15:56 -
Converting tv shows audio
By Oem in forum AudioReplies: 3Last Post: 1st Feb 2010, 22:42 -
No Audio after converting
By Seff7845 in forum AudioReplies: 1Last Post: 30th Sep 2009, 05:52 -
No audio converting flv
By holywoodhawk in forum Video ConversionReplies: 0Last Post: 11th Aug 2009, 23:38 -
Converting audio with glitch
By koberulz in forum Newbie / General discussionsReplies: 28Last Post: 7th Sep 2007, 05:55
