I have a 29.97 MPEG1 file that has an interesting pattern when viewed frame by frame in VDub.
Frame - Frame - Frame - Motion Blurred Frame - Motion Blurred Frame....
And etc, this pattern continues, two of every five frames are quite blurry, but only where there is motion. Moreover, the two blurry frames are identical! Obviously this was the result of some kind of conversion from Film to 30 FPS.
How can I delete the duplicate frames? Using AviSynth and the SelectEvery command won't work, since there is an extra non-blurry frame every now and then which shifts the pattern. But since the duplicate frame is identical to the preceding frame, I would think it should be easy for a filter to detect.
Results 1 to 1 of 1
Decimate odd patterned duplicate frames in video
By raphaelt in forum Video ConversionReplies: 2Last Post: 2nd Feb 2011, 22:57 -
Remove Duplicate Frames
By robindean in forum Video ConversionReplies: 26Last Post: 11th Mar 2010, 15:30 -
Frame blended and duplicate frames
By loekverhees in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jan 2010, 09:35 -
duplicate frames
By qscesz in forum EditingReplies: 5Last Post: 25th Feb 2008, 11:56 -
Can I decimate duplicate frames to get 23.976
By MagicSparky in forum Video ConversionReplies: 5Last Post: 21st Feb 2008, 15:26
