I created chapter points with vcd easy and was able to access them from win dvd on my computer, but both home dvd players only seem to recognize tracks and not chapters. Will any dvd player recognize chapters within a track of a vcd, or is there any burning software which allows one to write tracks manually?
Skudra,
Since you are able to access the chapter entry points through WinDVd I would imagine that encoding and authoring went well. At least if you are able to access them through the "Menu" button of WinDVD. If so, this would mean that you have the proper sequence headers before every GOP in your encoded MPEG and VCDEasy recognised them as such during the authoring process.
The only conclusion to make in that case is that your DVD players don't support PBC control, OR MOST LIKELY PBC control is switched off. If so, then chapter and entry points do not work either. Check your DVD players user guide for the PBC part.
Hope this is of help to you.
If you DVD player recognised them as tracks, then you probably made tracks.
Entrypoints are completely different to tracks. If you made tracks, you must have had ?separate MPEG files for each track?
To read more about entrypoint chapters: http://www.michaeltam.com/chapters.html
Regards.Michael Tam
w: Morsels of Evidence
have m2v+wav and chapter points, what's next?
By shun in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2008, 09:21 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 18:38 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
