I've been trying to make vcds from divx format lately to watch then on my dvd player. I use TMPGEnc to do the conversion. That works with no problem however the vcds are much to big to burn to a cd so im trying to "cut" them. I follow the directions on how do cut it with MPGEnc on this site however i get a Memeory adress error. I tryed to use My Flix 3.0 to cut it with and everytime i use that to cut it the sound is messed up with i play in on my dvd player. Does anyone have a recommendation on how to fix my problem or on another program i could use that would work better?
Try and get hold of a copy of
JIAO VCDCutter 4.01
There is a version 4.03 but I never got it to cut more than 7 seconds - even after proper registering.
I use this prog and get good cuts, you can cut to as many spilts as you like from your mpegs, eg 2, 3 ,4 5 etc
scattergun -
Don't edit a MPEG after encoding, if you have one more choice. You could cut the AVI. You could use TMPG's source range to encode in several parts. Have a look at Sefy's DVD ripping guide (your source is avi, but there is no difference using the source range) and use TMPG's batch encode mode.
whats wrong with editing an mpg after its been encoded? just wondering, because sometimes i need to crop a second or two off the end of an mpeg file.
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 11:38
