I have these 2 avi from Pink Floyd they are HQ, High Resolution, 320KBPS, 2 pass. I want to convert them to SVCD without loosing to much quality. Anybody qualified to help in this work??
Just dont want to loose to much quality doing it!![]()
This really isn't anything "advanced". I'd use TMPGenc and let it sit overnight. The settings in the guide in my sig will help you, though you may want to alter to 2-pass, leave at estimate since their probably isn't much motion, bitrate 2520 MPEG2 480x480 resolution. Let it sit overnight, may take 10 hours or so, but still better than the mosquito noise emitted by CCE. Procoder may be your only other choice, but I'd still suggest TMPGenc Plus for its ease of use.
I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
Big thanks will follow your advise. Did you say 2 pass?? not Constant Bitrate??
What do you sugest for the audio?? I usualy take GoldWave is it O"K??
I just want the best for that. I have about 400 movies and this is the nicest i've seen so far
Encoding a vob file to use in premiere pro
By spongela in forum Video ConversionReplies: 2Last Post: 17th Oct 2011, 19:31 -
Need help Compressing a File in Sony Vega Pro 10! PLEASE HELP!!!!
By CaptRicoSakara in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2011, 11:37 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
VOB2MPG 3.0 PRO - Output File Directory Suggestion
By SuperFist in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd Jun 2009, 06:03 -
how do i put srt file in dvd lab pro?
By oilpourer in forum Authoring (DVD)Replies: 6Last Post: 1st Jul 2007, 19:20
