Looking for information on this, I d/l the Demo, ran it on three different DVD's. On each run the program would complete about 80% process and then come back with an error and stop the process. My test were on the DVD to VCD mode. It seems annd the sites related to ths softwae are in German. Anyone know of a english site. Thanks
I've had a similar problem trying to rip to a handheld movie format. I specify the card size but the resulting file comes out way bigger, plus I get errors like you. I have today e-mailed the company to try and find out what's going on.
have you tried the www.engelmann.com website? There's a link to an English forum which I'm going to try later. -
have you registered it??
if not then it will only rip 80%..i have been using it 4 sometime and have np with it
but make sure you have aspi drivers installed..i use wincompel aspi
if you encounter the company logo of MJ in the top right corner, then go to regedit and type in "INITWM" and modify it to 0 (zero) -
hi mate i get same prob works ok in demo mode only vcd not svcd when put crack in no joy only 85% you say yours ok some one said change my os ihave millennium in the lad i got it from says it works ok on his with xp iam getting mj in conner like u said cand you tell me where this is
regedit and type in "INITWM" and modify it to 0 (zero) cheers -
Here's a clip from the website promoting the product. It's kinda self explaining...
The demo version has the following restrictions:
only 14 days functionality
no support for S-VCD/MPEG 2 ripping, no cutting and converting functionality because of MPEG2 license terms
no support for Dolby Surround
no support for Handheld-Movies for PDAs and Internet
To enable all missing functions, you just need to purchase and enter a valid serial number.
Anyway, It's not a good idea to be openly chatting about hacks and cracks here. Just use the demo for evaluation and buy the one you want to use.Only 3 things are certain in life... Death, Taxes, and SPAM. Of these, only Death seems affordable!
SVCDummy
