I have downloaded two programs (TV Show series) that when I try to encode them I get an error message. I run the file through gspot and in the video get message that there is a misconfigured codec. When I check further I get some info green hilite, others just normal. I do a render, then check that, also get some info in green.
Aside from handwriting everything down, is there any other way to get the info so I could post it here for some of you knowledgable folks to se.
From description and info I have given you so far, do you have any suggestions, or are these two files just lost causes.
Diane
Results 1 to 1 of 1
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
Re-Codec
By Casper_H in forum AudioReplies: 1Last Post: 21st Feb 2008, 09:10 -
which codec
By peterg60 in forum Video ConversionReplies: 6Last Post: 25th Jul 2007, 16:52
