i have about 60 700meg avi's to encode back to mpg to make svcd's.
i have tried a few tools and they are all saying 40hrs ish, anyone know of a fast but good encoder?
Results 1 to 10 of 10
What are your computer specs (I have a 2.1mhz..P4 and on average it takes me about 3 hours to do a 90min movie)
"Today is only yesterdays tomorrow" -
TMPEGenc Pro works pretty fast in VBR when you cache the 1st pass. Depends on system specs.
speed or quality?
on my system, Main Concept encodes at about 2x the length of the original file (10 minutes to encode a 5 minute file) versus TMPGenc's 5-6x (25-30 minutes to encode a 5 minute file).
The reason I stick with TMPGenc is that the quality is so much better than Main Concept.
as far as where you can get it, try http://www.mainconcept.com/mpeg_encoder.shtml- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
pc is a P4 2gig, 512 of ram, pref quality rather than speed.
Is there not a quick way of burning these to a single CD or should i look at DVD instead? -
to make movie fit on 1 cd its the bitrate that does it, eg if a film is 1 hour 15 mins i.e. 75 mins (700meg cd = 80 mins) normal vcd bitrate of 1150 is
fine, but this is where it gets weird
ive encoded films that are around 1 hour 50 (110 mins) that fit on 1 cd by lowering the bitrate, quality does go the further down the bitrate you make it but not much until you reach aboput 800 and less
if you want quality then you need to think about 2 cd's
try this link
www.data-uca.150m.com/vcdencoding.doc
tells you about working out bitrate and encoding etra -
I've tried just about every TMPGenc template out there and I still have'nt found one that can give me a half decent 1 cdr movie.
I'm sticking to 2 cdr...at 32cents a pop ,I'm not complaining."Today is only yesterdays tomorrow" -
Dude, if you are getting better quality from TMPGenc than you are with Main Concept, you are doing something seriously wrong with Main Concept.Originally Posted by housepig
On that note, Procoder kicks both their asses.
-v20"Did you see what GOD just did to us??" - Fear and Loathing in Las Vegas
Optimizing Settings for youtube upload like fast start etc for x264 encoder
By vibes992000 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Feb 2012, 23:30 -
Fast encoder to record game videos
By Arnulf in forum ProgrammingReplies: 23Last Post: 10th Aug 2011, 13:45 -
DVD to MPG/AVI/H264 for editing - desperate help needed
By BertRito in forum Newbie / General discussionsReplies: 19Last Post: 17th May 2010, 23:46 -
Fast Foward / Rewind xvid or mpg?
By fredfillis in forum Newbie / General discussionsReplies: 3Last Post: 8th Nov 2009, 04:06 -
Proper FLV Encoder needed - getting desperate!
By vk_dk in forum Video ConversionReplies: 3Last Post: 28th Feb 2009, 09:43
