  1. Ihave QT pro , but I cannot save the fullscreen versions of quicktime trailers. It always says "this movie does not allow saving" I thought that with pro i could do this, but i can't. Does anyone know any tricks.
    Thanks in advance
    May 2002
    Hi!
    Here are 2 websites where i download the trailers from. They usually have the direct links for them.
    http://www.kaneda.freeserve.co.uk/trailers.html
    http://www.jurassicpunk.com/index.shtml
    Hope this helps a bit.
  3. Hey,
    thanks for those sites! THE problem still remains though. after i save the trailer. When opened it has these borders, like the splash and poster image around the trailer itself. You can delete these, but on the trailers it says "this trailer does not allow saving" when you try. Any ideas?
  4. Member cplevel42's Avatar
    Feb 2003
    You cannot copy most of those trailers, even with Q-time Pro.
