Hi!
I just got a DVD+RW and would like to convert some HI8/VHS tape to DVD. What is the best capture setting (like 640x480) to convert to DVD?
Thanks.
LD
Capture at the highest setting you can without losing too many frames. Then convert as normal.
Hello. -
some people will say that anything over 352x480 is wasted on VHS source material. Personally, I disagree, so I capture at 720x480 as an avi with Huffyuv codec, 48Khz audio.
Then I convert to mpeg-2 with TMPGenc, at the same settings, 2-pass vbr with 224khz Layer-2 audio.
The result is an mpeg that's within spitting distance of the original quality.
your mileage may vary.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
can I ask what kind of equipment you use to capture? can what kind of connection to the pc? usb? firewire?Originally Posted by housepig
I have to agree with Housepig. I have the ADS IDVD, and it captures VHS at 704 x 480. And when I convert to a DVD, I cannot tell if I lost any quality at all.
Hello. -
352X480 will be your best bet if you have very little h/d space to work with but if you have anuff and want the best Q than go for 720X480 you will not see much difference between the 2 if your vhs looks like shit but i use 352X480 on VHS stuff all the time and i can't tell the difference my eyes arent that great anyway
my guess would to be to make samples and name them and burn them all onto a dvd+rw and see what one looks the best name them like tmpgenc4pass.m2v or cce18pass.m2v or whatever program you use and pick which one looks the best.
good luck.[ = Check out my band @ www.samadhirock.com = ]
VHS/Hi8 to digital using ADVC110. Some questions.
By Jull in forum Capturing and VCRReplies: 9Last Post: 5th Jan 2012, 13:23 -
Beginner's Approach to Digitizing VHS/Hi8 Tapes?
By Obtong in forum Newbie / General discussionsReplies: 8Last Post: 10th Jul 2011, 23:08 -
converting Hi8/S-VHS or even VHS to digital
By lawncowboy273 in forum Capturing and VCRReplies: 2Last Post: 23rd Dec 2010, 19:30 -
What I want to do: Transfer/capture old VHS and Hi8 family tapes.
By Boomer1948 in forum Capturing and VCRReplies: 7Last Post: 4th Jan 2008, 23:19 -
Vdub filters on my HI8/VHS before Authoring..
By nopk in forum RestorationReplies: 6Last Post: 8th Dec 2007, 18:34
