I've been burning onto my DVD-RW Disk for... probably a hundred or more burns... Always burning at 2X, and it works fine. I have a pioneer A05 burner (Been using the RW that it comes with, 2X media) Then last night, when I tried to burn it again... it would only let me burn at 1X? So I tried... put it into my DVD player, and now it's all skippy? It never did this before... I thought it might have been windows, so I formated -_- and it does the same thing... is it because I used my RW too much, or what?
Try formatting it...and not the quick format. Use the full format option, or however it's named. Also, make sure the underside is both clean and unscratched.
How do i format it? I found a way to once, but I havent ever seen it again... I did an erase, a full one, didnt do nothing
What do you burn your discs with? Any burner application has a command that lets you perform a full erase on an RW disc. I use Nero; there the option is in/around the Choose Recorder menu.
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 16:35 -
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 13:04 -
converting broken avi file to dvd
By dvdnewbie64 in forum Video ConversionReplies: 1Last Post: 14th Dec 2008, 20:05 -
Have I Broken My DVD Writer? Region Change!
By VideoGeekUK in forum DVD & Blu-ray WritersReplies: 8Last Post: 31st Jan 2008, 13:52 -
Broken Guide Line DVD authoring questions
By Clessoulis in forum Authoring (DVD)Replies: 7Last Post: 8th Jan 2008, 00:05
