I'm using DVD Decrypter, DVD Shrink and IMG Tool to author my DVD's
All of a sudden when I go to burn the DVD, IMG Tool keeps telling me to insert a blank media, when I know for a fact the media is new.
I am using the latest Nero(downloaded last night) and it stills happens.
Please help.
Any suggestions?
could be the new version doesn't like your media
i had some cheap media that nero didnt like after i upgraded
just a thought. -
no, because it was happeniong before that, thats why I d'loaded latest version. I've burned 20-30 dvd's with this method. All of a sudden it started giving me this error.
Hello
There are two different versions of ImgTools. I use the "classic version" which I downloaded from the doom9 website. I use it after using DVD2ONE to create an image which I then burn using DVD Decrypter.
This is being done on a SONY VAIO computer which came with a Pioneer A04/104 DVD-R/RW burner.
So far I've only burned DVD-R discs on it but no problem using ImgTools (classic) and then DVD Decrypter to burn.
- John "FulciLives" Coleman
P.S.
The one time I used NERO to burn a DVD-R from a VIDEO_TS folder made by DVD2ONE the resulting DVD-R would only play in one of my two stand alone DVD players. After doing it again using the ImgTools/DVD Decrypter method the final DVD-R played on BOTH of my stand alone DVD players. I used the same brand of DVD-R discs on the same computer both times.
Please note that the doom9 website has a guide on using DVD2ONE using the ImgTools/DVD Decrypter method. It is very easy to do."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Originally Posted by DoubleShadowIce
Hello
Have you tried the "classic" version of ImgTools and if so have you had any luck doing so?
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 21:05 -
Are you able to insert blank video into hd h264 without reencoding?
By yoda313 in forum EditingReplies: 2Last Post: 5th Jun 2010, 23:42 -
Blank DVD Media
By jason in forum Newbie / General discussionsReplies: 21Last Post: 2nd Dec 2008, 11:40 -
Blank media revisited
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2008, 09:57 -
Insert blank frames at end of video
By kidcash in forum EditingReplies: 5Last Post: 28th Jan 2008, 04:52
