Hi,
I've had my Epson 900 printer for a few weeks now and really do like it. I've printed about 50 discs on it and noticed a problem since the beginnning.
About 3/8" from the bottom of the printed dvd there is a space about 1/2" wide that prints just a little lighter. I believe my plastic tray may be a little warped or maybe there's some sort of internal problem. Just wondering if anyone else has noticed a similar problem?
Thanks, Jerry
Results 1 to 14 of 14
Hi m8 yes I had the same problem but when I use Verbatim DVDr they are perfect. Sadly my printer printed photos with visible line structure which was not due to blocked heads so I have had to return it and got a replacement which done the same so I have now ordered a 950.
I also have one but got no problem at all.
I print both disk and photos and everything's better then perfect__________
d0oM969 -
Hi,
No problems other than some DVD-R media not drying after printing! I have printed a number of discs which upto a week later have still not dried - and yes, they were sold as printable media.
Bill -
I bought it locally in N Ireland but PC World are doing it on the web for £304 or £379 in store (work that one out) as are Dabs.com I paid £315 but at least I can return it easily if something goes wrong.
vcdlover,
The US model of the 950 is the 960.
http://www.epson.com/cgi-bin/Store/consumer/consDetail.jsp?BV_UseBVCookie=yes&oid=22403490
Newegg.com has them in stock for $318 + $6 shipping..
I plan on picking up a 900 once they come available locally as the 960 is a little more than I want to invest just for printing on my disc blanks..
Another thread here suggested using a spray to seal the disc blank to prevent smearing..
Regards...
Rick -
I was about to post and ask if anyone had this printer-cause i had a question about media.....spooky
I always buy ICE 4x DVD-R and was wondering if anyone had tried to print on these. They have quite a glossy finish - but i dont how the Epson would cope.
If they work-i'm straight down to DIXONS
cheers everyone...
Barry -
Is the ICE media that you are using Ink-Jet printable? If not then the Epson won't be able to print on it. The ink either won't dry or will bead up.
the web page i get them from isn't exactly full of details. i was just wondering if anyone had used them as. I always get these dvds as they are only 99p each and i didnt want to was £300 on a printer and then realise i need to buy £2 media....
BReeve you dont have to spend £2 on media SVP are doing 2X Verbatim printables for £1.65 each in jewel cases, which in my experience are the best available, the inkjet surface produces far superior results than any other I have tried. Bigpockets are also selling Opti 1X inkjet printable for 99p each although I am not sure what dye there using.
i need 4x as i burn quite a lot of DVDs
...ooh well looks like i'm stuck with the labels for now.
cheers anyway...
Epson Generic Printer Ink - Here I Go Again!
By leebo in forum MediaReplies: 12Last Post: 29th Apr 2011, 15:28 -
INKJET printer - print heads
By orfajackson in forum Newbie / General discussionsReplies: 13Last Post: 15th Aug 2009, 06:51 -
Sharing Epson Printer
By stiltman in forum ComputerReplies: 0Last Post: 1st May 2008, 23:12 -
Epson R 300 Printer - Print CD Software
By karlosfandango in forum ComputerReplies: 5Last Post: 29th Nov 2007, 12:12
