I have recently upgraded to the most recent version of TMPGEnc Plus but all I get is problems. It even crashed my PC and I had error messages after rebooting.
Has anyone else had similar issues and are there any solutions out there?
Results 1 to 10 of 10
I've had a few sticky probs with it. I've had to restart encoding after getting like 40% when it says "can't read film". But once it actually finishes, it makes a marvelous end result. What kind of problems are you having?
I often get read errors and violation codes but sometimes it works ok but I'm getting very nervous using it because sometimes when WinXP restarts I get this message saying that it had to recover from a serious error.
I had similar problems in the past, I went out and picked up a program called SystemSuite 4.0, let it run an all-in-one clean, jet defrag, virus scan the whole works. It takes care of messed up registry values and the like. It's made by Ontrack and isn't too pricey. Might be worth a look.
I suspect that there maybe something stored in the temp folder that causes problems so I have cleaned it out and at the moment everything seems OK - touch wood!
http://www.v-com.com/download/index.html Here's the link for the trial version if you want to try it. They have tons of trial software.
A problem I'm having is with 2:3 pulldown. It crashes TMPGEnc at various percentages never the same place. The way I get round it is to babysit the process by starting and stopping encoding every 5% during the inverse telecine. Anybody have the same problem or found a solution!
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
