hi
got some old tv programs that iv been asked to share but the file size is quite large. is there any way to compress them into a smaller file. each episode is about 25 minutes long and the file size is about 230 meg. the episodes where captured as avi from vhs using virtualdub then run through tmpegnc to get the mpeg.
you can take the original .avi and run it through TMPGenc again, and lower the bitrate further.
or you can take the mpeg file and run it through TMPGenc, and lower the bitrate, but the re-encoding will probably make for some really ugly video.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
im quite new at this but wont lowering the bit rate lower the quality, thats something id rather not do
If you have the original AVI I would save it as a DIVX or XVID .
"Today is only yesterdays tomorrow" -
how do i save it as a divx do i have to re-encode it or can i use something to just save it as divx
you can open the file in Virtualdub, under Video select Compression, and choose a Divx codec.
I thought you needed to maintain an mpg file, which prompted my initial answer.- housepig
Housepig Records
out now:
Converting videos -> smaller file size
By karib in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 14:31 -
Can I get VOB to smaller file size with no loss of quality?
By Joolz2020 in forum Newbie / General discussionsReplies: 17Last Post: 23rd Aug 2010, 13:11 -
Best way to convert DV file to something that have smaller file size
By Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 06:14 -
Smaller file size after Video Capture (help)
By convoy71 in forum Capturing and VCRReplies: 4Last Post: 4th Apr 2009, 17:05 -
Converting MPEG into a smaller file size?
By ione in forum Video ConversionReplies: 3Last Post: 9th Sep 2008, 22:36
