How do I correct or edit something that is now in .mpg2 format? The original .avi source has been deleted - I needed the space on my drive. Is there an good editor for .mpg2 files? Or do I need to "re-convert" it back to .avi to do the editing? If so, how do I do that? Thanks.
it depends on what do you mean by editing
cutting something out?
adding a transition?
editing mpeg2 is not a good idea (in most cases),
you cant cut it where you want, i think it has something to do with the gop.
but if you have no choice, you can do it.
cut it using tmpeg (mpeg tools).
you cant add transitions
hope it helps...HELL AINT A BAD PLACE TO BE -
Thanks for the reply. I guess I need to change it back into an .avi file. What is the best way (e.g. program) for doing that?
2.35:1 AVI plays back stretched on HDTV
By stormdragon in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2011, 19:11 -
Burned DVD Back to .AVI
By Iambob in forum Video ConversionReplies: 9Last Post: 1st Jun 2010, 19:42 -
ripping a avi/mpeg back onto computer
By pw29010 in forum DVD RippingReplies: 2Last Post: 16th Feb 2009, 17:34 -
AVI back to Mini Dv
By thewdawg in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 8th Oct 2008, 15:18 -
AVI file won't play back
By Clydesdale in forum Software PlayingReplies: 9Last Post: 4th Apr 2008, 00:22
