Why is it after i split a film using V dub mp3 and then encode each seperate file I then encode using tmpg the sound disappears, could somebody please help
Nickbfc, post up as much detail as you can, video codecs, audio codecs what are you using Vdub for ? etc etc.
The more info you provide the greater the chance that someone will be able to help. -
If its VBR you may have to extract the audio and "SAVE AS A WAV" in Virtualdub then use resulting WAV as Audio source in TMPGenc.
If its a XVID feed directly into TMPGenc.
I have had much better success by splitting the movie during the encode process(ie:In TMPGenc ,I use Source Range,Save 2 projects and then Batch Encode.)"Today is only yesterdays tomorrow"
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 01:11
