I have 3 large mpeg 2 files that I want to splice into serveral files. I want to keep the split files as mpeg2 so i can burn as a DVD.
So I Have 3 large mpeg2 files with sizes of 765MB, 4.70GB and and 6.34GB..
I have donwloaded a program named Easy Video Splitter that will splice the large mpeg2 files and keep the output as mpeg2.
The program is having trouble splicing the 4.70 and 6.34GB files
When I try to split the large files In Easy Video Splitter I get the error message "The source mpeg file is invalid! Would you like to get more help from DoEasier.org?"
However the program can split the 765MB file.
When you run Easy Video Splitter you can split the video manually. The video loads up in the program and you move a slider to where you want the splicing to start and then move the slider to where you want the splicing to stop.
I can also use Easy Video Splitter as a sort of windows media player and watch the files I am about to splice.
Easy Video Splitter will load and play all 3 of the mpeg files but it will only split one of them (the650 mb file)?
Does anybody have any ideas or any ideas as to how I can turn my large mpeg to files into individual dvd movies?
I have also now tried a program named DVDcutter Stream. That will also not split the 4.70 and 6.34Gb files but it will cut the 735mb file?
All 3 mpeg2 files I am trying to cut are from the same recording source so there should be no differences in the files apart from size. -
I am using Win XP with service pack one
120 GB hard disk
512MB ram
Geforce4 ti 4600 graphics card
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 16:44 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
Inaccurate file splitting
By Blå_Mocka in forum Newbie / General discussionsReplies: 11Last Post: 13th May 2008, 04:19 -
Splitting avi file
By tryst1 in forum EditingReplies: 2Last Post: 15th Nov 2007, 03:33 -
Looking For A Cropping/Splitting/Converting Tool that supports MPEG2
By LordOfTheStrings in forum EditingReplies: 21Last Post: 12th Nov 2007, 12:09
