I know I can demux, re-render and re-author to remove the copyright vob from my backup but that's a lot of work. Is there a quicker way to do this?
Preview the vob in vobrator to find out which vob_ids contain the warnings, or whatever else you want to remove.
Load the ifo for that vob in IfoEdit and click Vob Extras/Strip Vob_Ids. Set a destination dir and hit OK. Check all items except the ones you want to remove and click strip it. It will strip the warnings and output a new vob in the destination dir. It will also create a new Video_TS vob and ifo. Replace your old files with these, load the Video_TS.ifo in IfoEdit and click Get VTS Sectors down at the bottom.
Now your done. All together it takes about 1 min to do. -
Well this sounds interesting but could you give a bit more detail? How do I preview in Vobrator? I loaded video_ts.vob. Demux just creates a bunch of m2v's, an ac3, and .spes (whatever that is) files for the whole vob, not just the selected vob id.
okay, I guess you click the play button to preview. One thing: when clicking stop to stop the playback the vobrator program shuts down. This must be a bug....(happens on my xp system)
I run XP as well and Vobrator doesn't do that. Sorry, no idea what is going wrong there. Make sure you have the latest release, and if you already do, then maybe try an older one. Of course when running XP, whenever something doesn't work its a good idea to try running it in compatibility mode. Right click the executable and go to properties/compatibility mode and try running it in 2k mode.
What do you recommend for burning the dvd after stripping? Nero seems to make coasters (altho they play on the pc, I get nothing on my dvd playerOriginally Posted by adam
I'm not a fan of Nero for DVD burning. I recommend using IMGTools .89 (don't use later versions) to make your files into a DVD disk image. From there you can burn using the very good and free program, DVD Decryptor.
CopyToDVD is also good for burning, and free to test. I also lost loads of blanks through nero, but not one from this prog.
Test warnings
By alfresco in forum TestReplies: 3Last Post: 1st Feb 2010, 06:35 -
Secret Copyright Treaty Leak: ISPs Worldwide to Become Copyright Cops
By joepic in forum Latest Video NewsReplies: 17Last Post: 5th Nov 2009, 11:05 -
Eclipse report says 0 errors or warnings. . .
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2008, 14:48 -
Are there any players/firmware hacks to allow skipping of warnings/preview?
By Sephiroth666 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 14th Mar 2008, 08:37 -
Laser printer warnings?
By Bartron in forum ComputerReplies: 8Last Post: 8th May 2007, 13:07
