I have ripped a dvd using eazyvcd but the the video doesn't have any substitle. How can I get the subtitle to be included in the video
thanks
Probably the easiest way to create a (S)VCD from DVD and include the subs would be to use DVDx. Check out Sefy Levy's complete DVD backup guide here: https://www.videohelp.com/sefy/ and in particular the section about encoding from the DVD with DVDx, here: https://www.videohelp.com/sefy/?id=direct1.html
This probably isn't the best way to go in terms of video quality but it is easy and effective. By all means check out the subtitle guides on doom9.org however most of these methods require alot of steps and can be very time consuming. Goodluck. -
Personaly i'm not a big fan of "All-In-One" programs, at either rate, DVDx does not offer the best encoding quality, or matchable to TMPGEnc, i'd recommand you use the VirtualDub + VobSub method, you can follow this:
http://www.digital-digest.com/dvd/articles/dvdtovcd/LSX.html
Just instead of LSX use TMPGEnc or any other encoder you like.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
How to extract idx/sub subtitle from dvd source video without vobsub rip?
By cairuitao123 in forum SubtitleReplies: 7Last Post: 20th Apr 2014, 13:31 -
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 01:48 -
forced subtitle problem in avi.net with dvd rip of main movie only
By nathanm in forum SubtitleReplies: 0Last Post: 30th Apr 2010, 10:37 -
ccextractor DVB-T Subtitle rip
By raketten in forum SubtitleReplies: 1Last Post: 7th Mar 2009, 12:59 -
Help! Rip Chinese Subtitle
By balonglong78 in forum SubtitleReplies: 6Last Post: 19th Dec 2007, 09:38
