Hi with my win98 i used to be able to capture perfectly with huffyuv, but now in win2k it skips and freezes and looses voice, i changed my drive settings to DMA and defragmented and it still doesn't fix it, could it be because my drive is ntfs, i tried all types of capture software, i can capture in mpeg2 in 352x288 using power vcr, but i prefer Huffyuv mjpeg,
my pc is pIII 800mhz, 512MB ram 20GB HDD, help.
thanks
Bilal
Things do not always go right with an upgrade. You are always much better off doing a clean install from scratch. Have you tried uninstalling/reinstalling the HuffyUV codec, or if you can't uninstall it, then reinstalling it over top of itself?
sorry i forgot to mention i've formatted the drive and installed win2k with sp3.
Hello,
I'm using Win2000 sp3 with huffyuv with a ntfs drive and have no problem at all.
What capture card do you use? If it's a BT8xx chip base card, use the btwincap drivers.
Also, Win 2000 uses WDM driver instead VFW, for capture. So please, use Virtual VCR to capture. It's free and it's the best IMHO.
Also, try to capture without sound. Check for drivers, etc...
Pitou.
Windows 7 is out, have you upgraded?
By Baldrick in forum PollsReplies: 84Last Post: 6th Jan 2012, 17:56 -
I upgraded an old PC and use it to rip BDs
By barkinglama in forum Newbie / General discussionsReplies: 37Last Post: 30th Sep 2010, 19:36 -
Upgraded Again!! TYSM Redwudz
By 16mmJunkie in forum ComputerReplies: 1Last Post: 31st Aug 2010, 11:48 -
Have you upgraded to a HD camcorder?
By Baldrick in forum PollsReplies: 18Last Post: 8th Nov 2009, 20:36 -
Have you upgraded to WIFI N yet?
By yoda313 in forum PollsReplies: 14Last Post: 25th Jun 2007, 20:16
