Im capturing DV from my PAL camcorder. At the end of the capture pinnacle studio 7 comes up with "your studio7 is not PAL enabled" . Anybody knows how to do that?? Further more, I thought there is no PAL AVI or NTSC AVI...How about any other capture/edit software (rathern than studio 7 ) that can handle both PAL and NTSC??
I think the very first time that you install Studio 7, it asks you if you want PAL or NTSC. You must have chosen NTSC at the time. To make it PAL, I suggest you uninstall it and clean up the Windows registry with the tool that is provided on their support web site. Then do a new install.
For more information you can check with the folks on the Pinnacle forums.
BTW, I think there is a difference between PAL AVI and NTSC AVI.
Pinnacle Studio 8
By Victri in forum Newbie / General discussionsReplies: 1Last Post: 24th Dec 2007, 05:18 -
Pinnacle Studio 11
By fjmr in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 04:44 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 19:53 -
pinnacle studio 11
By serega in forum Latest Video NewsReplies: 14Last Post: 13th Sep 2007, 19:14 -
Is anyone using Pinnacle Studio 11 ???
By maxtrack in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 23:56
