When I render and/or convert, which field order should I start with, A or B? I use Ulead Media studio 7 and/or Ulead VideoStudio 7 to edit and render to NTSC DVD format. It gives me the option of which field order to start with, I have been using "A". I capture my DV to Ulead VS7 then usaully edit and render with MS7.
Also when I convert the rendered DVD video file to NTSC VCD format in TMPGenc it again gives me the field order option. I have been agian using "A".
What field order should I choose any why? Does it matter?
I watch the VCD's on a regular NTSC TV and the same for when I get a DVD burner.
95% of the time it's field A with DVD. I usually use the TMPGenc wizard to tell me which field just in case it's B. I just open the wizard and close it afterwards.
When I render DVD with Ulead MS7 the defualt is field "A". Then when I convert to VCD with TMPGenc, the defualt goes to field "B". I change the TMPGenc to "A" to match the DVD rendered video. Is that right way to do it? Keep all conversion consistant with the same starting field?
I read in the glossary on this site that if the wrong field order is used then video could have flickering. But it doesn't mention how to correctly choose the correct field order before rendering and/or converting. -
I use field order A(odd) 100% of the time.In TMPGEnc and MPEG-1 if you use the wizard it will default to A but the normal GUI will default to B.MPEG-2 is the reverse...very strange.
Here's a simple guide:http://www3.telus.net/dvd/mpeg/svcd/encoding_video.htm -
I've always used "A" and never had any flickering. So I guess I will stick with it and not wonder about it anymore. Seems like "A" is the norm.
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
> Ulead VS11 Broken MPEG 2 Field order <
By Dark Alpha in forum EditingReplies: 8Last Post: 24th Jun 2008, 09:29 -
Field Order Problem?
By GordRocks in forum Authoring (DVD)Replies: 3Last Post: 4th Mar 2008, 10:19 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14 -
About TMPGEnc judging field order
By jmayme in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2007, 14:56
