Hey all,
I am expieriencing problems with my new dvd drive for computer. I just bought a Pioneer 16x model 116. I love the drive so far, and it plays the dvd's just fine. However then i tried to rip(backup) Austin Powers 1. I had no problem, i ripped it at 7x - 9x all the way and i was able to get the rip. Then i tried Austin Powers 2. It started off at 2.2x - 3x as a rip speed. I thought this was a bit odd but i left it go. It got about 22% done, the blue screen flashed for about 1 second (windows 2000 style) and then reset my pc. I then went back and tried Austin 1 again and had exactly the same prob as i had with Austin 2. Im really stumped on this one. Any ideas whats going on? I have updated my firmware, same prob. And im using smart ripper.
Thanks in advance
Best regards
Antilooped
i belive smart ripper is very good, but try another dvd copier to see how it goes...can't hurt to try
Hello again,
Just in reply to the last reply, i tried DVD decrypter, and it did the first chapter then got about 5% into the next one and i got the smae prob, except this time, i saw what the blue screen said - something about ntoskrnl.exe and a memory problem, i know its not much, but if anyone knows the solution to my prob, or what ntoskrnl is, i'd be appreciative
Best Regards
Antilooped -
Okay i have another piece of information...
when i try to copy a normal data cd to my hdd, it does the blue screen error thing after a certain amount of data has been copied. And the Blue screen msg is "Beginning dump of physical memory"
i believe a complete scan disk with disk surface examination is in order.
i really dont know but perhaps you have a error in a very important sector of your hdd. -
Oh man I know what your going thru. Just happened to me today (except it happened no matter what prog. I opened) heres what I gathered from all my searching actually the problem is there was a fatal "Stop" error and as one of the recovery functions of Win2k It tries to copy or "Dump" the memory to the hardrive. For some solutions try to upgrade of SP2, and also go check out http://www.computing.net
Good Luck (I had to finally reinstall win2k)
Mike
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
Again blue screen!!!
By alintatoc in forum ComputerReplies: 10Last Post: 10th Dec 2009, 14:16 -
Blue screen?
By alintatoc in forum ComputerReplies: 19Last Post: 1st Nov 2009, 06:53 -
what's a blue screen?
By aruwin in forum ComputerReplies: 8Last Post: 23rd Sep 2009, 08:56 -
Blue Screen Of Death
By Squid_uk in forum ComputerReplies: 15Last Post: 31st Mar 2008, 14:35
