Please can someone help with converting to DVD. Have converted ntsce movie (Xvid dvd rip) to pal, as original encodeing which worked ok was jerkyon dvd playback. Read in forum convert to pal would help with this.
Converted video only to pal fine, and used goldwave to convert audio file to pal using timewarp option.
Loaded both pal files into Tmpgenc, selected pal options using wizard, and hit encode. First off though selected System (video & audio) automaticly reverted to ES(video & audio). when encoding.
Ended up with M2V file which which has no audio!!!! and separate Wave file.
Tried to multiplex using Tmpgenc (I think am meant to do that???) but won't let me.
What am i doing wrong that I get 2 files.
Didn't have this problem when did ntsce encode!
Please can some one point me in right direction as this is really frustrating me
To multiplex in TMPGEnc I think the audio must be MPEG, to encode, however, WAV is supported. Which one are you trying to do?
Encoding trailing effect PAL > NTSC
By KarenM in forum Authoring (DVD)Replies: 0Last Post: 10th Jul 2010, 13:04 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
Gamma encoding for PAL DVD
By absence in forum Video ConversionReplies: 0Last Post: 9th Jun 2009, 08:53 -
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 6th Jan 2009, 23:25 -
Influence when selecting PAL or PAL 16:9 with TMPGEnc
By Purno in forum Newbie / General discussionsReplies: 4Last Post: 7th May 2007, 04:24
