Hello: I use this program :VCD Copy X 1.1 to copy a vcd. I've got a .dat file and I want to make a vcd. How do I do it? I tried with the vcd tools but the video was very jerky and the audio sync horrible.
Thanks in advance for your help
easy...
Rename the .DAT file to a .MPG extension and drop into toast.
If toast refuses it, do a .mpg to .mpg conversion in VCD gear telling it correct bad MPEG blocks and drop onto toast again. If toast still refuses it, build a .BIN image in ffmpegX and drop that onto toast in VCD mode.
Hope this helps. -
It worked just with renaming it. I burnt it with vcd builder.
Everything was cool
Thank you everybody
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 04:50 -
how to copy the contents from a scratched vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 36Last Post: 28th Dec 2007, 02:03 -
copy contents from vcd
By sumeshkri in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Dec 2007, 00:34 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 07:20 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
