  1. I have been using tmpgenc to convert all my avi files, and it is great. I was just wondering how long it usually takes everyone to convert a 700 mb avi to mpeg 2.
  2. I've had it go as long as 18 hrs and as fast as 9. Depends on the qiality of the finished product that you want. Also depends on wether or not you're using the pro edition so you can take advantage of the cashing function.
  3. I must be doing something wrong. I have a Pentium 4 1.5 with 256 ram, and the avi I am converting now says it will take 60 hours.
    Dec 2002
    Texas USA
    I never go more than 3x realtime. (i.e., a 2 hour movie may take 6 hours to encode).
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Not necessarily, if you're using any of the built in filters then encoding time is increased dramatically.
  6. Human j1d10t's Avatar
    Feb 2003
    California, USA
    When I encode about 45 minutes of video it can take anywhere from 3 hours to 21 hours, depending on the resolution, if I'm upsizing or downsizing the resolution, and what (if any) filters I apply. I've also found that which filters I use also affects the encoding time - i.e. the noise reduction filter takes longer than the deinterlace filter.
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
  7. Member scottb721's Avatar
    Oct 2002
    Australia
    I have an AMD1800 on Win XP Home.
    These are with no filters and high quality (Slow) motion search.
    For a DVD conversion to SVCD, CBR is 2 times movie length and VBR is 4x
    Captured AVI to SVCD, CBR is 3 x source length and VBR is 6x
