Please can someone help with converting to DVD. Have converted ntsce movie (Xvid dvd rip) to pal, as original encodeing which worked ok was jerkyon dvd playback. Read in forum convert to pal would help with this.
Converted video only to pal fine, and used goldwave to convert audio file to pal using timewarp option.
Loaded both pal files into Tmpgenc, selected pal options using wizard, and hit encode. First off though selected System (video & audio) automaticly reverted to ES(video & audio). when encoding.
Ended up with M2V file which which has no audio!!!! and separate Wave file.
Tried to multiplex using Tmpgenc (I think am meant to do that???) but won't let me.
What am i doing wrong that I get 2 files.
Didn't have this problem when did ntsce encode!
Please can some one point me in right direction as this is really frustrating me.![]()
ES- elementary stream. Means TMPG output a video only (M2V) and audio only (WAV) files.
You can compress your WAV (which is uncompressed audio) to mpeg1 layer 2 audio.
Most DVD authoring apps accept sep. streams. What DVD authroing software are you using. Including TMPG's DVD authoring software. -
Thanks for the reply. I have now managed to compress the wav file into mpeg1 layer 2 audio by downloading Toolame and using that in TMPGENc. Then was able to simple multiplex using TMPGENc result MPEG file with audio.
In regards to your questions:
I extracted WAV from original movie(which I downloaded from net) with Goldwave.
Converted original movie to 25fps with virtualdub (NO audio, video=direct stream copy, change frame rate=25...save as avi, name movie as "movie"25.avi)
then used Goldwave to convert audio to pal rate as stated above.
Oh I also used FourCC changer on movie to make TMPGenc think it was a DivX rather than an Xvid.
When did my first encode of movie using TMPGENc as NTSC, (sep streams )got one MPEG file, no problemas let me use stream type system(video & audio).
Really puzzled why cant using pal. Oh the pal version is definitely not as jerky.
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
