Does anyone know where I can pick up CCE Pro encoder. It is not available at the CCE homepage. And one other question. I am using CCE lite right now, whenever I try to encode one of my avi(s) I get an error from CCE stating that it was looking to start from 0 instead of 8 or something like that and it does not create the mpeg for me. Anyone know what I might be doing wrong?
CCE Pro is a real time MPEG-2 encoder, that comes along with a frame capture card and a decoder card.
Visiting their homepage you probably noticed, that there is no fixed price, but a "ask us abour the price"
If an average MPEG encoder like CCE SP (this is the one, that is used by most people) is almost USD 4000, what do you think will cost CCE Pro? That's why it is not available at the homepage and probably nowhere else. -
I see said the blind man...hahahaha you are exactly right. I cannot believe that tehy want 4000.00 for a board and encoder, for that it should be able to do big time Bollywood productions.....I mean Hollywood...hahaha. At any rate Trueman, can you maybe tell me what I am doing wrong with CCE Lite version then?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Actually, there are 3 encoders: Lite, SP and Pro
The lite version is just a couple of hundred dollars. The SP version is $4000. Both of these are software only. The Pro version is the one with hardware bundled with it. It's price is so high, they couldn't fit the numbers on their website.
The company I work for sells CCE Pro bundled with Zapex MPEG2 encoder cards. The starting price is $6200.00 and it goes up to $15000.00.
Oh, good heaven above. I'll just stick with my AIW Radeon card. $200 some dollars, and plays games too.
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 12:41 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 16:27 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04
