Hi guys,
Before I formatted my PC I was able to download a movie (using kazaa), convert it to MPG using TMPGEnc and fit it onto one VCD using the guide on this site. This meant I could get a whole movie onto 1 CD. Great.
Since formatting my PC I have not been able to do this.
If I take an avi movie and use virtualdub to extract the audio and then use TMPGEng to convert everything to mog the size of the file shhots from around 750MB to around 1074MB. Much to large to fit onto ine CD.
What am I doing wrong? I know it's possible as I used to do it. Am I using the correct setting?
please help. I upgraded my PC just so TMPGENC would do it's job faster. (Got the time from around 12 hours to around 1.5 hours!!)
Thanks.![]()
Results 1 to 13 of 13
Is the .avi file the same length or bigger?. Also is your bitrate setting the same ?...one of the last steps in the wizard lets' you know what your resulting file size will be and gives you option to adjust this according to the media you are using.........I know this all sounds obvious but It's a start.
There's a version of TMPGEnc that has a bug which defaults all mpeg1 encoding to the VCD standard of 1150 Kb/s. You might want to try a newer version.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks for the advice guys, but it ain't helped.
When using the wizard, at the last step I can choose the media (74min VCD) and sellect the "use 100% of disk" setting which resets the bitrates to the appropriate levels. Now before this used to solve the problem and the movie would be compressed to fit on the disk. Not any more.
I am using TMPGEnc 2.5 if that helps.
I have a horrible feeling that I am missing some vital software (codecs or aspi or something). -
Version 2.5 what? I did a search and it's version 2.59 that has the bug.
That's the one with the bug, get a different version and you shouldn't have any problem.
You can't use the 80min VCD setting in the wizard???Originally Posted by alanpark"Today is only yesterdays tomorrow"
I could select the 80min disk setting if I had any 80min disks, but I only have 74 minute disks, hence the reason I select the 74min VCD optio.
all stop
simple answer is bitrate
standard bitrate for vcd is 1150
what you need to do to fit on 1 650 cd is work out the bitrate
so you need a bitrate calc
on the tools section is a list of calcs
i recommend the one by tomas zavodny
you type in the length of movie (time) and how many cd's you want it on, and it show the bitrate, then in tmpgenc, you load up your usual, bits and pieces and then before encoding load the unlock template goto the option where you change the bitrate and type in what the calc said
then click start and then you will have a mpg that fits
now before you say "but the final size is still bigger than my cd size"
i know its weird but a 800 mpeg file will fit on a 700 meg cd so a 740 meg file will fit on a 650 cd
try burning it you should find it fits
have a look at
www.data-uca.150m.com/vcdencoding.doc -
With all due respect......are you using circa 1997 cdr's??
I've never seen 74min cdr's in several years in the stores I shop (unless you are talking about cdrw)"Today is only yesterdays tomorrow"
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 07:10 -
TMPGEnc, Vobsub and mpg files as source
By kubak in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2009, 17:52 -
MPG with TMPGEnc
By koberulz in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 18:43 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 02:52
