Man, i i'm in trouble!
I was trying to watch the mpgs i converted w/ TMPGEnc and i was not being able to do it, so i searched for a MPEG-2 codec and i think i isntalled one but now i cant see any mpg file!!! I try with Winamp 2.91, Windows Media Player and RadLight and it always shows this message: The Program generated an error and will be closed by Windows.
I am so mad w/ this stupid computer!!!![]()
Can anyone help me???
HELP ME PLEEEEASE!
i just realized i can open the mpg in Quick Time, but only in it....
thats weirdHELP ME PLEEEEASE! -
try VIDEOLAN, a free Mpeg2 player with integrated codec.
If it works, you can uninstall the others and just keep QuickTime.
Ciao -
Try to find Dxman.
In a rather recent post, by Baldric, if I remember correctly, around March 15~25th, this utility was suggested as a tool to remove unwanted codecs that were causing problems. The URL to obtain it is either in the post or you will find it in the tools section.
I've used it myself and seems to do a fairly good job removin specific drivers.
And never install any codec you find without second thoughts. Consider unknown codecs a potential danger. I never try any of these unless I have made a ghost image of the system disk before. If the codec is causing problems, I just restore the ghost image and no harm is done.The more I learn, the more I come to realize how little it is I know. -
well, it played w/ Videlan
and about the dxman it showed me a list of codecs and only one was showing error but i chose to remove and it doesnt remove...HELP ME PLEEEEASE! -
did you try to remove using standard Windows way?
for 2000/XP
Reboot
click on "Settings"
-Control Panel
-System
-Hardware
-Device Manager
double click on -Sound, video and game controllers
double click on -Video codecs
click on the "properties" tab
click on the codec you want to remove.
click "remove"
Messed up finalizing a dvd
By spunon in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2009, 14:06 -
my DVD and HDD messed up
By goodguyswearblack9 in forum DVD RippingReplies: 8Last Post: 20th Apr 2008, 02:11 -
How did most of my video files get messed up?
By Powder in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2007, 00:08 -
timecode messed up
By snafubaby in forum EditingReplies: 4Last Post: 20th Sep 2007, 05:00 -
Nero messed up again, need an alternative.
By capman21 in forum ComputerReplies: 5Last Post: 12th Jul 2007, 10:19
