I'm having trouble converting a DivX avi of the Matrix with 25fps to mpg2 23.9
I tried using MainConcept (which I really like), but during the action scenes, the actors movments aren't fluid. The motion slows down.
Any ideas? I want to use a program that allows me customize my output (like MainConcept).
Thanks!
I've not used Mainconcept (Yet), but I know in TMPG the VBR setting pretty much takes care of all that action stuff by assigning bitrate where It's needed and throttling back where It's not, might be worth a try......or does Mainconcept do that also?
Hope this helps
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 02:01 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
