  1. Can anyone tell me what kind of luck they have had with these?
    http://www.supermediastore.com/optodisc-gold.html
    Also have you been able to burn at 2x with upgraded firmware?
  2. Yes, I got it burn at 2x with 1.3 firmware of pioneer 105.
    May 2003
    Port Author, Texas
    I only use optidisk gold with my pioneer 105. Not a single coaster yet!
    Dec 2002
    Texas USA
    These discs work wonderfully.
    But don't hack your drive. It's not worth it. If you need 2x, buy true 2x discs. That is a HACKED by Gradius/NIL, not an official release of any kind. Hacks have been known to ruin -RW discs, destroy -RW functions of the drive, hurt read abilities of the drive, and remove all CD-R usage.
    From that firmware README:
    Drive: Pioneer DVR-105/DVR-A05 (DVD-R/RW Burner)
    Firmware Rev.: v1.30
    Patch: RPC-1 (Region Free) + 2xDVD-R + 12xRip
    Date: 2003.04.07 - 23:35 GMT
    Authors: zaitec2, >NIL: & Gradius for the write strategy
    Release Notes: This is the release version of the 2x4all DVD-R
    including the anti 2x Rip Speed patch
    The 2xDVD-R patch DOES NOT affect the burning process
    for media media that already burned at 2x.
    The 2xDVD-R enables burning non 2x DVD-R's at 2x BUT
    PROPER BURN IS NOT GUARANTEED! It depends on the media
    Flashing Instructions: Make sure you don't have Intel Application Accelerator
    installed. Then run UPGRADE.BAT. This should run fine
    on Japanese systems as well. For more info:
    http://forum.rpc1.org/viewtopic.php?t=12632
    Useful Links: http://forum.rpc1.org/ (See: DVD-R/RAM/+RW)
    http://pioneerdvd.rpc1.org/
    Thanks to: Flash, Depl0y and everybody who contributes to the
    R/RW section of the forum
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
    Jan 2003
    Toronto,Canada
    One blue top coaster and one unsuable white top DVD-RW for me. Other than that they've been fine.
  6. well I flashed my drive last night and burned a dvd-r and a cd-r with no problems. Also love the improved ripping speed. Obviously this thing isn't right for everyone but it works for me.
    Jul 2002
    I ordered 2 50-packs gold top and use up about 25, they're perfect if the size is below 4.25 GB. They burn at 2X with 500AX in 2.0 USB box.
    vcdlover
