I've been using it for a year with VirtualDub, and it worked great. I used the BTWinCap driver. Suddenly all I would get was a green screen, but i could hear sounds. I tried uninstalling/reinstalling, and it doesnt work. But i did put it in a different computer and it works fine. i dunno whats wrong, please help.
Sounds like a system restore may be what you need. If you meant by unistalling/reinstalling, you meant the card, you should make sure your drivers are uninstalled and reinstalled as well.
Hello. -
Uninstalling something doesn't neccessarily delete it. You need to manually delete the INI files associated with the card. For my 'BTWIN' experience, it was 4 files. Unfortunately the actual name varies from computer to computer.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Ok, I reloaded and everything works fine again. But now I have a mono audio wintv because i lent my dbx-stereo one to a friend so I'll need to get that one back. I'm starting a new project, i want to convert the Indiana Jones trilogy from VHS to some digital format. I was thinking of using CVD since i can get better bitrates and squeeze more on a disc. I was wondering if i would have any trouble capturing for 2 hours straight with my CPU specs. The capture settings I'll use are:
352x480 resolution
YUY2 video format
HuffYuv compression
44110khz WAV 172kbps audio
and i have NTFS HDD's so thats not a problem...if anyone has any advice let me know.
HELP! broken mp4
By RWB713 in forum Newbie / General discussionsReplies: 3Last Post: 13th Apr 2013, 18:40 -
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 12:04 -
Broken Codecs
By jdubbsmoney in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2009, 20:05 -
broken mp4
By Andy_B in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 15:43 -
help with broken TV...
By snadge in forum Newbie / General discussionsReplies: 5Last Post: 2nd Sep 2008, 12:03
