Hi there,
There are several guides here explaining how to convert NTSC <=> PAL DVDs and I know that SECAM is similar to PAL system. Now my questions are:
1- Do we have such a thing as SECAM DVD like the way that we have NTSC or PAL DVDs? If we do, then
2- If I have a SECAM DVD, can I just convert it to NTSC (or vice versa)with the same guides? (I noticed that some of the softwares that perform these conversions, they only have a PAL / NTSC options)
3- If I have a SECAM DVD, does it play on a PAL DVD player?
Thanks for your help.
[Just to add to the confusion, there are hybrids of the 525-line 59.94Hz interlaced video that use the PAL color encoding and vice-versa. And when a signal is transmitted, there is another layer of difference that you might have seen indicated by terms like "PAL-M" vs. "PAL-G."]
But we almost always deal with the digital domain on this and other similar sites, and at that level things are either 525/59.94i or 625/50i. It is at the point that the video is converted from digital to analog (or from analog to digital) that the PAL/SECAM differences emerge.
So you can take a "PAL" DVD, put it into a DVD player designed to output SECAM, and view it on your SECAM TV. Of course in reality, you are likely to have a TV capable of dealing with both SECAM and PAL, and perhaps even NTSC or the hybrid mentioned above.2- If I have a SECAM DVD, can I just convert it to NTSC (or vice versa)with the same guides? (I noticed that some of the softwares that perform these conversions, they only have a PAL / NTSC options)3- If I have a SECAM DVD, does it play on a PAL DVD player?
Xesdeeni -
Adding my 2c, I regularly convert European dvds (that I buy) to NTSC.
All dvds in Europe that I bought (including the ones from France) are in PAL. -
Originally Posted by cmangeot
- John "FulciLives" Coleman
*** EDIT ***
I'm not saying the SECAM format does NOT exist at all ... I use to buy import VHS videos and know better ... all I am saying is I have never heard of a SECAM DVD"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Whew...this is an aptly named thread
OK, the link you provided was for a VHS/DVD combo. The VCR part adds to the complexity, so let's discuss that below. For the DVD part, the output will most likely only be PAL. But since all SECAM TV's (apparently) accept PAL inputs, there is no problem there. SECAM is only really used for over-the-air transmission (even in the television studios, all the equipment is PAL, and the video is converted to SECAM just before it is transmitted), so it's not necessary for the DVD part.
Now, the VHS part adds an input to the device. This includes a tuner, which now needs to deal with SECAM. Internally, the SECAM will be received and then almost certainly be converted to PAL, which is what is stored on the tape. It is certainly possible that there are SECAM tapes, since VHS tapes are analog, but it is my understanding that converting to/from SECAM and using PAL for the tape itself is more convenient for everyone (you can trade tapes with other countries, and they don't have to manufacture special versions for SECAM countries).
Xesdeeni -
I just wanted to thank you all specially Xesdeeni for the informative replies. It was really useful to me.
can a PAL disc work fine in a SECAM system ?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2012, 04:55 -
PAL DVD work on SECAM?
By BobAchgill in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2009, 06:20 -
VHS capture jumping between PAL and ME SECAM...help
By pijetro in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2009, 18:55 -
Help! - ntsc and secam versions of chapter authored pal dvds
By devdev in forum Video ConversionReplies: 3Last Post: 25th Aug 2008, 21:05 -
h.264 digital format to PAL, SECAM, NTFC formats in DirectShow ?
By manzoor505 in forum ProgrammingReplies: 1Last Post: 8th Dec 2007, 08:28
