UltraISO is a CD image file creating/editing/converting tool , it can directly edit the CD image file and extract files and folders from it, as well as directly make ISO files from your CD-ROM or hard disk. At the same time, you can maintain the ISO bootable information, thus creating your own bootable CDs. You now have the power to make and edit your own ISO files, and then burn them to CD for your own needs.
Whats NEW
Can convert CD image to .NRG and .BIN/.CUE format
New Graphical User Interface in Windows XP style
Main menu included
Skin and sound effect options
Support Windows explorer to UltraISO drag & drop
Show "number of files" and "total size" property of both Image and Local directory
Whats FIXED
Fixed hung up problem when open an empty ISO file
Some minor bugs fixed
http://www.ezbsystems.com/ultraiso/index.html
Results 1 to 1 of 1
UltraISO Question
By m02499 in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2010, 01:12
