when i set up the input settings for dvdx then click ok i get an error message saying "The output and input frame rate are not equal.Pull Down (up) will be performed". any explanations please.
Try reading the guide which comes with DVDx, and try encoding anyway to see if its a big problem!
1)Why Not Overclock a little?! speed 4 free!!!!
2) If your question has anything to do with copying PS2/PC/XBox games, find a more appropriate website -
I would read the guide if i could get it but you need a vip pass from the makers of dvdx so that you can download the guide unless someone has a guide around that i can download
i have just downloaded DVDx 2.2 from http://www.doom9.org/index.html?/leech.htm under decoders. i installed it and the guide was installed with it! just go to start, programs, dvdx, GUIDE!!!!
overclocking is increasing the speed of a component of your pc (usually the processor), thereby making it faster. itis not reccomended for the inexperienced as if not done correctly it can damage your hardware! if you want to learn more go to www.futuremark.com1)Why Not Overclock a little?! speed 4 free!!!!
The message means that the frame rate of the original film is not the same as the frame rate of the film you are creating and DVDx will change the frame rate for you. If say you have set the frame rate for the (s)vcd or avi you are creating at 29.97fps but the frame rate for the original film is 23.97fps, DVDx will change the frame rate to 29.97fps.
Error message! Help!
By XAPHSNYC in forum MacReplies: 6Last Post: 8th Feb 2010, 14:05 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 14:17 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
