Strange problem with my computer. Whenever I try to play this SVCD i have, the cd will spin and act like its loading up, but then just crashes whatever program im playing it in..i've tried a lot of programs and it crashes them all, even PowerDVD, windows media player. It's not a bad burn or anything because it works fine on my other computer. I'm sure I have all the right codecs, so I dont know whats causing it to not work. Im using windows xp, athlon 1.8GHz, 512 ram if that helps. Anyone have any ideas? Thanks in advance.
Windows Explorer crashing when trying to rename/play video files over 5GB?
By yatesl in forum Software PlayingReplies: 4Last Post: 18th Dec 2011, 20:19 -
What is the best software can play HD videos?
By rm2dance in forum Newbie / General discussionsReplies: 6Last Post: 16th Jul 2011, 18:23 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 06:54 -
svcd problem crashing with SP3
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2008, 17:38
