I'm quite anal and a little concerned about my HDTV. I recently put a PAL SVCD in the player and switched the player output to PAL the television started to flicker crazily and I quickly turned it off. Can I damage my TV by sending it such a signal....and on normal TVs I have sent PAL signals to without a prob....should I plug the player into a non HD connection and try again?
capturing PAL signal as 1080i, 720p or just PAL ?
By adom in forum Capturing and VCRReplies: 3Last Post: 30th Aug 2011, 06:10 -
HDTV-Bad Signal?
By crowheart in forum DVB / IPTVReplies: 11Last Post: 29th Oct 2010, 02:31 -
Direct TV/HDTV Signal Question
By RKelly in forum DVB / IPTVReplies: 5Last Post: 12th Mar 2010, 01:55 -
Does CW do something to their HDTV signal?
By mattman1968 in forum DVB / IPTVReplies: 3Last Post: 9th Jun 2008, 09:21 -
convert PAL HDTV 1080i -> PAL DVD 576i
By halsboss in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 22:13
