    Jan 2003
    Milwaukee
    I'm using Mac and working with the program (imovie). It won't support or accept the mpeg. Is there a way to convert mpeg to dv stream? (without using parts to convert, but program)
  2. What iMovie are you using? If you're using iMovie 3 you should be able to drag and drop the mpeg into the clip pane window. (For some reason it doesn't allow you to File:Add Clip/Open? a mpeg.
    Or you can open the mpeg in quicktime pro and try converting it. If you don't have quicktime pro try opening it with MoviePlayer. (An old skool mac os 9 quicktime pro LITE version, Free) and the convert it.
    Good luck
  3. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Quicktime Pro will export mpeg1 to DV Stream with no audio. iMovie will then accept the resulting DV Stream.
  4. See chapter "How can I convert MPEG back to DV" at:
    <http://www.sjoki.uta.fi/~shmhav/SVCD_on_a_Macintosh.txt>
    Jan 2003
    Milwaukee
    Thanks ya.........
    and a special thanks to tgpo for getting me the idea
    of quicktime pro converter.....
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Glad to help
