Field order "lower field first" is what: Field order A or Field order B?
Thanx.
All I know is when I load a DV AVI into Premeire, it reports Lower Field first.
When I load same AVI into Ulead, it reports Field order A.
As far as I'm concerned, Field order A = Lower Field first.
Premier says all DV AVI is Lower Field first.
Ulead says all DV AVI is Field order A.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Unfortunately, as mentioned above, if you dont know the source field order, different software may report it differently.Originally Posted by txpharoah
Besides the mpeg merge/cut features, this is the only other thing I find useful about tmpgenc, it tends to report field order correctly. So I load my file into it, check what it says is the field order, and then go encode with good software using the reported field order from tmpgenc.
-v20"Did you see what GOD just did to us??" - Fear and Loathing in Las Vegas -
Hello everebody. Thanx for your replys. The final result was found thanks to "txpharoah". I see the web page he sent me and i found that expresion: "Top firld first (field A)" It means that DV cams using field order B. Thatīs the problem - espesialy with Ulead - it uses field order A. There was no problem with video until I used only DV. Now I transfer my old records from DV to DVD and the video is jerky at the places with speed motion.
do I have a field order problem ?
By davexnet in forum Video ConversionReplies: 9Last Post: 13th Dec 2010, 14:41 -
Field Order Question
By daz1976 in forum DVD RippingReplies: 2Last Post: 11th Feb 2010, 10:27 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
Reconciling different Field Order
By vegasarian in forum EditingReplies: 8Last Post: 14th Mar 2009, 12:43 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
