I am searching to encode SVCDs at max bitrate of 1400, as my DVD player will lock if bitrate is higher (Samsung 709.)
My idea is to prevent macroblocks in high action scenes : what would you advise, with, for instance :
> duplicate frames to reduce "apparent framerates" while making macroblocks disappear ?
> apply a "motion blur" filter in Vdub ou Avisynth to reduce macrobloks ?
> blending frames ?
> change resolution only for these scenes
> reduce sound bitrate during theses scenes ?
Thanks for you suggestions !
My suggestion would be to forget all the grief and get another cheap player like the Norcent DP-300 or DP-215 from Wal-Mart at $50US. Those players will play just about anything you put into them...
Assuming you asked this because your too cheap to buy a new player
, you should consider using CVD resolutions (352x480), instead of SVCD. It will produce a better image a lower bitrates that SVCD. If your player will play SVCD, it will play CVD. You should also use Multipass when encoding. It will allow better bitrate allocation to the busy scenes. You can expect reasonable output using multipass VBR, and CVD at that bitrate. It depends on the input. Other tricks you can do invovle letterboxing your input, so more image area is plain black. This is an extreme fix, as most people don't want to sacrifice image area for a busy scene or three.
Impossible to see the future is. The Dark Side clouds everything... -
Thanx DJRumpy. I read somewhere that SVCD what visually (almost) same quality as DVD, whereas in CVD, the difference in resolution was clearly visible. What have you noticed ?
There isn't that much of a difference between CVD, and SVCD. 128 Pixels in width to be exact, or about a 3rd of SVCD's width. Between SVCD, and DVD, there is almost twice the horizontal resolution of SVCD. The difference is that CVD will look the slightest bit softer, with the benefit of less compression artifacts (macroblocks). Done properly, they should appear to be just about identical to SVCD. If your not sure, just try a small clip. I'm would bet good money that the CVD clip will look better at 1400 kb/s than the SVCD will on high motion scenes.
An SVCD would require approximately a 11:1 compression ratio to produce an mpeg that was 1400 Kb/s. A CVD would only require a compression ratio of 8:1 to produce the same Kb/s.
A sizable difference (more compression = poor quality).Impossible to see the future is. The Dark Side clouds everything...
VHS-->DVD, "action scenes" and bad sources
By Jdrive in forum Capturing and VCRReplies: 7Last Post: 13th Oct 2010, 01:09 -
High Quality At Low Bitrate?
By sanosuke in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 09:21 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 19:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11
