Okay i have an svcd i want to make it into an avi merge the two parts then convert it to dvd-r, Converting it to dvdr isnt no porblem i know how to do that. Its riping the svcd into an avi, I try Virtuadub (boht the normal and mp3 one) and its says pack sync error.
Any other programs that will convert a svcd to avi? or can anyone else figue out how to do it. I want to merge the parts of the svcd (its on 3 cd's yopu see) then put it on a dvd-r. If i could merge the mpgs or convert it to avi then merge the avi's i dont mind but please HELP any way you can
Thanx
Andy
If a computer Bites you BYTE it back -
Are you using the virtuldubmod that supports mpeg2?
http://home.attbi.com/~blade66/
or
http://virtualdubmod.sourceforge.net/
Or try dvd2avi. Crop if it is ws and save as avi. To get the audio choose save as project to get the mp2 that you can convert to mp2/wav with for example besweet.
But if you are converting to dvd I would recommend to instead frameserve with dvd2avi, open all svcd mpgs and then save as project and convert with tmpgenc www.dvdrhelp.com/mpeg2tovcd
Encoding .Avi to Svcd?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 13:40 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
