  1. Hi
    I am trying to make mpegs out of a Fawlty Towers DVD with 6 episodes on it. (series 1)
    I have successfully ripped 3 episodes (1st three) but always get an error when ripping the other three.
    The error I get is-
    BESWEET has caused an erroe in VOBINPUT.dll
    Besweet will now close.......then I get
    TMPgenc has caused an error in Kernel32.dll.
    I have taken the DVD back to the shop & tried a new copy but still the same.
    Have you got the latest version of Eazy VCD (1.15)? YES
    Have you installed one of the ASPI Layers from the website (www.eazyvcd.tk) and restarted after installing? YES
    What version of windows do you have, and what service pack if any? WINMe
    What is the DVD you were trying to RIP, and what region is is R2 Fawlty Towers V1
    Is the DVD you are trying to rip, copied (eg on a DVD-R\W)? NO
    Can you play the DVD in your software DVD player (eg PowerDVD)? YES
    What files (if any) are in the "Output Folder"? 2 files
    In the "Eazy VCD" program folder (C:\Program Files\Eazy VCD\), is there any files named temp.txt or temp01.txt ect ect? NO
    In the root of your C: drive (C:\), is there any files named temp.txt or temp01.txt ect ect? On desktop
    If those files are there, could you please e-mail them? 32 mb, tempa_1.mdat, tempb_1.mdat, tempc_1.mdat
    thanks for any help
    Nigel
    ps
    have successfully ripped All 6 episodes of Series 2
  2. ANYONE Please!!
  3. Can all DVDs be turned into mp4 or do some have stange quirks?
    thanks in advance
    N
