hi
i wanna copy my films from my dv-cam to my pc and i wonder if sb could help me with this issue. i know firewire cards exist but i wanna to do this way first:
from the DV-cam i used a AV-cable which in the end splits up in to a composite and one audio left chinch and one audio right chinch. since PCs only habe one audio-in and dont support chinch i used an adapter which combined both chinch cables in to one 3,5mm which then fitted in my audio in. i started my capturing programme (tv-card software) and saw the picture alright but the sound was only mono. i checked all options (system tray, control panel etc) but couldn't find a solution to bring the audio to stereo. So now i would like to know how can i get the video incl. the audio of dv-cam on to my pc without yet using firewire???
i also have:
-ATI radeon 9000 (not Pro) with s-video In/Out, composite In/Out
-Tv-card with s-video-in, composite-in, AV-in and antennas of course
i would appreciate any help
thx
tommybs
Results 1 to 9 of 9
kazaa rules...
you should get a firewire card (about 50$) as you are losing massive quality really ..
otherwise whats the point about having a dv camera -
Originally Posted by tommybs
The other thing is... are you plugging it in to the Mic input on your soundcard, or the Line In? The Mic input is often mono, whereas Line In will be stereo.
Sorry if these seem like stupid questions!
cheers,
mcdruid. -
line in of course
can u tell me where u can get a stereo jack then?
kazaa rules... -
See my reply to your thread in the Capture Forum. it sounds like you need Maplin code N85AN or you could use DG27E and QT64U. The first is a twin phono socket to stereo jack adapter, the second two are a twin phono to stereo jack plug cable and a back to back connector
well, i ve got one like these (maplin code N85AN) and where i got it from it says its stereo! this is the one i have http://www.edigicam.de/web66/product_detail.jsp?showDetail=80525
its german but u still see its stereo etc. or am i wrong?
greetzkazaa rules... -
It looks right, its got tip, ring and sleeve on the jack plug end. I assume you are using the line in socket on your soundcard and not the microphone socket as the mic input will be mono? Does the plug fit properly into the socket or is something stopping it from going in fully? If it isn't in fully you will only get one channel connecting. That's why I prefer to use a cable with an ordinary plug, it isn't as bulky.
just got mixed up with ur last post but do u mean i have to stick the jack in to the mic in or the line in???
kazaa rules... -
Put it in the line in! The mike socket is almost always mono for reasons unknown, very irritating when you try to use a stereo mic..
if you need to test, get a stereo jack to stereo jack connector, put a tape or disc with wide stereo into your walkman, plug end to end, and record from each socket. use the volume control's recording segment (usually you have to go through the file menu or something to find it) to make sure all the other sections are muted off and it's not accidentally set to 'everything mono' or balanced off to one side..
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
Preference for MP3 Joint Stereo Vs. Stereo ?
By davexnet in forum AudioReplies: 7Last Post: 27th Oct 2011, 11:49 -
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 19:05 -
I keep losing stereo audio on my stereo bluetooth headphones (vista)
By yoda313 in forum ComputerReplies: 0Last Post: 30th Jan 2010, 09:19 -
Does anyone know how to convert joint stereo audio back to stereo?
By robrosen in forum AudioReplies: 1Last Post: 2nd Aug 2009, 22:24 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 09:33
