In the configuration for divX 5.0.5, the default Encoding Bitrate is 780 kbps. What does Encoding Bitrate mean? What does it do? And also, at the top of that, there's the default 1 pass. What is it. Can we change it?
The clue is in the title, i.e. it is the bitrate at which your source is encoded. In this case 780000 bits per second!
check our glossary
https://www.videohelp.com/glossary#Bitrate
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Minimum Bitrate MPEG2 encoding
By Rob D. in forum ffmpegX general discussionReplies: 4Last Post: 14th Jul 2010, 09:44 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34 -
Batch encoding with a frame quality parameter instead of bitrate ?
By ronpub in forum Video ConversionReplies: 27Last Post: 21st Jul 2008, 18:42 -
Problem with bitrate and file size when encoding with XviD
By megakoolkid in forum Video ConversionReplies: 13Last Post: 25th Jun 2007, 17:12
