I want to burn a DVD+RW with Nero. I know when I'm using a CD-RW with Nero I usually check "do not finalize CD", but with the DVD feature, that's not an option. So my questions is, if I burn a DVD+RW with Nero, will I be able to write on it again? Is there something special I need to do so Nero won't finalize the DVD? This may be a stupid question, but I'd appreciate an answer![]()
I'm using Nero 5.5.9.17.
Thanks![]()
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
Don't worry, when it finalises the DVD it just means you cannot add more to it in another session. DVD-Video does not allow for multi-session (ie. writting more than once to the same disk, without wiping it first in between). Multi-session writing is only good for writing data, not movies, hence why the option is not available.
It does not mean you can't format your DVD again and start anew.The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be. -
Cool. I didn't want to turn a DVD+RW in to a coaster - I don't mind doing that with CD's, but they are really cheap. Must appreciated
Zefram Cochrane
2073
question about how to burn Nero Image
By jimdagys in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 11:06 -
Nero Recode question
By wulf109 in forum Video ConversionReplies: 1Last Post: 4th Aug 2009, 07:55 -
nero 8 question
By m-man in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 13:38 -
Nero 6 audio editing question
By Rad17 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2009, 23:53 -
Nero 8 transcoding question...
By RaGuSNY in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 14:23
