I have a 6GB mpeg2 file on my desktop containing a few films. I need to split the films up into their own individual files. I need to be able to split the mpeg2 file by minutes rather then file size (so the file contains only the start and finish of the film). I also need to keep the output file as mpeg2. Can anybody recommend a good program to do this?
BBMpeg. Incidentally, it is the only mpeg2 cutting program that I trust. Try the bbmpeg cutting guide in the EDIT section.
You can use the Merge and Cut feature in TMPGEnc. Go to File, MPEG Tools, then Merge and Cut.
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 17:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18 -
MPEG2-->MPEG2 Crop + Resize
By wincrazy in forum Newbie / General discussionsReplies: 26Last Post: 24th Jan 2009, 02:30 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 09:45
