  1. I am trying to use the plugin TomsMoComp in AviSynth to deinterlace my video, but no matter which application I use (Virtualdub) I keep getting the same error: 'TomsMoComp: Supports YUY2 and YV12 color formats only'. The thing is, I captured the video in YUY2 format, so I cannot figure out why it is giving me that error (if this matters, I used Huffyuv to compress it). I even tried adding 'ConvertToYUY2' in the AviSynth script and still gives the same error. This is the script:
    LoadPlugin("C:\Downloads\1\Avisynth_2.5_Alpha\Toms MoComp_Avisynth\Release\TomsMoComp.dll")
    clip = AVISource("C:\Documents and Settings\b\My Documents\Capture\#3 Finished\2.avi")
    ConvertToYUY2(clip)
    return clip.TomsMoComp(1,15,1)
    I have messed with this for hours, tried researching it, cannot figure out why I am getting that error. Everything used is the most recent versions. Any help would be appreciated,
    Thanks.
    Sep 2001
    Japan
    have you tried:
    clip=ConvertToYUY2(clip) #or clip=clip.ConvertToYUY2()
  3. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Do you have force RGB output, or always suggest RGB output set for Huffyuv?
    My script is usually much simpler
    LOADPLUGIN("C:\Program Files\AviSynth 2.5\plugins\TomsMoComp.DLL")
    AVISource("G:\capture.00.avi")
    TomsMoComp(1,30,1)
    Is clip=this and clip that really necc? I've never used it, and have never experienced any problems.
  4. It works now! I enabled 'always suggest RGB output' in the Huffyuv properties. Works great now. And that clip = ... thing, I just tried that by using an example I found, but it is not needed. I just downloaded AviSynth a few days ago and am still messing with it. It just baffled me why it wouldn't work, just something simple that I never had to change before.
    Thanks everyone
