Hey!
It's a real pain. I wanna cut out commercials from Mpeg2 file and
programs like Winproducer and Tmpegenc reencode the file 1 more time!!
It is way longer than jus cut and join like avi with Vdub.
Is there any faster soft not changing the edited file??
Help me!
I use honestech video editor 5. Works great and rejoins fast when combined.
Jim -
Mpeg can only be cut on an I-Frame. Regardless of what program you are using to cut, this is always going to be the case. Programs like TMPGenc and such are not re-encoding the whole file, they are inserting an I-Frame at the specified point, if one does not already exist, and are re-encoding all the other frames in that GOP. The only way to avoid this is to only allow cutting on an I-Frame, which many mpeg cutters do, but then you do not get frame accurate cuts. This is actually a much better way to cut though because it maintains sync better. I have never got a compliant, in sync mpeg out of TMPGenc's cutting options and personally, I think it is the worst mpeg2 cutter on the market.
BBMPeg does a good job of cutting mpeg2. Other than that, I don't really have any recommendations. Cutting and joining mpeg2 is just really messy. -
u can use TMPgenc to cut and join mpegs, file<tools<then i think its de-multiplex and then later u have to multiplex it again. dont ask me the exact way but one othe guides here under edit help u do that!!!
kazaa rules...
Soft Anti-copie
By youneslalami in forum ProgrammingReplies: 8Last Post: 30th Dec 2011, 22:46 -
what edit soft for old pc
By runnernorth in forum EditingReplies: 12Last Post: 1st Mar 2010, 03:33 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 15:39 -
Soft Sub to Hard Sub
By taylordotcom in forum SubtitleReplies: 1Last Post: 20th Feb 2008, 01:35 -
[solved] Major MPEG2 Cutting issues. Looking for program that will work.
By ShadowBlink in forum EditingReplies: 17Last Post: 17th May 2007, 19:55
